I’ve got a five year old roll top desk with a finish that’s developing a greenish tint. The nice folks I bought it from said the wood is cherry. It’s not, but it had a dark reddish cherry appearance when it was new. The finish seems to be a stain with maybe a polyurethane (or something else to give it a glossy finish) top coat. I’d like to bring back the darker, reddish finish it had when it was new, but I don’t want to go through the trouble of stripping or sanding the whole desk. Is there another way?
You could apply additional top coats with a bit of dye in it, as a toner, to change the color. Offsetting green is a bit of a challenge since the neutralizing color (opposites on the color wheel) would be purple. So you would likely end up with something like a magenta toner to end up killing the green and bring this back toward red. It's going to take a lot of experimentation. You might consider shellac as the toner material since it is easily reversible.
Turning green is a bit odd. Most oil based finishes tend to yellow over time. And even woods with a tendancy to green, such as poplar, would generally start with the green tinge that would turn brown over time. Must be an dye as a part of the original finish that is misbehaving.
Thanks for the reply. Would I just ask for a shellac toner with a megenta tint and then add that to a polyurathane?
No, you will have to mix this yourself, and you can't mix shellac with polyurethane varnish. Start with some blonde shellac (Zinsser Seal Coat will do) and mix a few drops of TransTint dye into it. I would start with a couple of drops of purple and a bit more than that of something like red mahogany. You want the color to be subtle. It should take 4 or more coats to get to the color change you want. If you try to do this in one or two coats you will have a hard time avoiding uneven color, even if you spray. It will probably take a lot of experimentation to get it looking right. Then, if there is some reason to have a lot of protection, you can overcoat the shellac with varnish. Be sure that the shellac is dewaxed or poly and waterborne finishes won't stick over the shellac.
I would be tempted to try briwax's Mahogany/cherry wax. Might be a simple easy fix.
Bruce S.
