I have some Super blonde shellac flakes that I tried to dissolve, as usual, in denatured alcohol. I was trying to make about a 2 lb cut to use as a sealer coat. The flakes only partially dissolved despite frequent agitation, after 3 days in solution. When I decanted the liquified portion of the shellac, the bottom 1/4 of the jar was a partially solid jelly made up of the softened flakes. The shape of the individual flakes was still discernable. I had used the shellac form this container before, without a problem. It has been on the shelf, dry, for about a year. I had also used the alcohol before, for French polishing. Just out of curiousity, I re-suspended the mass of jelly flakes in another jar of alcohol, and almost none of it dissolved even after 2 weeks. What could be the problem?
Jay
Blonde shellac deteriorates in flake form as well as in solution. Only orange (or amber) shellac can last indefinitely in flake form. I think you'll have to throw it out and buy new.
Thanks a lot. I have never read that anywhere. I thought all flake shellac should last indefinitely as long as it's dry. Have others had the same experience?
Jay
Hi all,
I hadn't heard that either. I just purchased some ultra blond from Homestead and I don't think it was mentioned. You might try asking over there too. I'm interested to hear the conclusion (it seems since my son was born shellac sits un-used MUCH longer - LOL). Erich
My source was Understanding Wood Finishing by Bob Flexner. It's a really well organized, informative book.
Before you replace your shellac, try some fresh solvent. Alcohol absorbs water from the air, and loses much of its solvent ability in doing so.
Also, store your shellac flakes in an air tight jar, and in a cool, dark place. Some of my less frequently used varieties of shellac have been in jars for years, and are still fine (last time I checked, at least.)
Also, when I mix shellac, I chuck a plastic paint mixer in the drill press at its slowest speed, and let it mix the shellac while I'm doing something else in the same room, keeping an eye on it. This gets it thoroughly dissolved in a couple of hours. You have to make sure the container can't slide off the table, and you shouldn't leave it alone while it's mixing, but I've found it an expedient way to prepare a quart or two at a time.
Michael R
Hey Jay,
Over the years I have had trouble with blond as well as orange flakes. Problems such as dissolving, wrinkling, and drying. I was never sure exactly what the problems were - just mixed new finish and started again.
An alternative is Zinsser pre-mixed shellac. It's dated on the bottom of the can. Available at Home Depot. I'm a finisher by trade, - I've never had a problem with this product. Go figure!
SA
