Hi all. In the market for a used bandsaw, have someone willing to sell me one.
It’s a Jet 710116K JWBS-14DXPRO 14″ Deluxe Bandsaw, 1.25HP 1PH 115/230V.
Attached is a picture of it. Is $1000 a fair price? What should I look for when I go to inspect it?
Appreciate any insights.
Vince
If it is indeed the deluxe model with 1.25 hp. motor it retails for around $1800. There are many models of this saw so make sure it is the deluxe model. It looks clean. Make certain it runs well, the blade tracts well and no strange noises. There is not much to go wrong with this saw. I own the same saw with a 2 Hp motor. My only complaint about the saw is the height adjustment for the top blade bearings. You pretty much have to readjust the bearings after adjusting the height. It is not a big deal but a little annoying. If the saw is pretty new $1000 is fair but no more than that. Hopefully some blades will be included with the purchase. It should be just adequate for some resawing. It really is best for pattern sawing.
I think the price is a bit too high. ACME has them on sale for $1500 with free delivery. I would value the used saw at around $750 if in good condition.
Like Hotdogman said, be sure it's actually the Deluxe model and not just a regular bandsaw with a riser kit.
It’s a bit shy on horsepower and a new one details at $1400 at Woodcraft, I am really not sure it will be a pleasant experience to resaw 12 inches with it, so if it’s for cutting curves and resawing 4 inches a brand new one with 6 inches throat opening will cost about the same and if you go one step above, a 2 hp with 120 pounds more steel will go for $1750 , $750 would be my price for this one.
If you want a bandsaw that can resaw tall boards without frustration, here are 3 that aren't much more than $1K and are far better than the JET (IMHO).
Rikon 10-324TG $1,087 (sale price good for 5 more days)
Rikon 10-326 $1,359 (sale price good for 5 more days)
Grizzly G0513-A40 $1,550 (price includes shipping)
Guys thanks for all this feedback. I thought the price was a little high and I think I am going to pass on this one. Mike, I am going to take a look at those Rikon's, as I think I will be more comfortable buying something new. Thanks again for the feedback folks.
Buy it directly from a proper seller like Acme for the Rikon or from Grizzly for the Grizzly. Don’t buy it from Amazon or a 3rd party seller or the warranty may not be honored. When you register it after purchase, you’re usually asked for the receipt which shows the seller.
I own that very same band saw you are looking at. I just came from my shop after resawing a cherry plank 2 inches thick by 10 inches wide. I use a carbide resaw blade. The now matching results came out just about right without any issues. Is it the greatest bandsaw in the world, no. There are many others at a much higher price that may be better. Is it an adequate saw for a shop, yes. There are people on this site who are willing to give an opinion and that is about all it is. The saw you are looking at retails for around $1800. Yes, you can find it advertised for less but that does not include the shipping charges. If you can buy that saw for around half price and it is clean and runs well count your blessings.
I swear I saw it for $1400 at woodcraft, it’s $1800 ! But is ships for free.
It’s still $1800 at Woodcraft, but Acme is selling it for 1400 with free shipping: https://www.acmetools.com/jet-jwbs-14dxpro-14-deluxe-pro-bandsaw-kit-710116k/731325167689.html
Beware: Whatever you buy make sure of several issues. Does the blade height adjustment return to its locked position the same each time you adjust the height. Does the table tilt operate smoothly and does it return to the same zero position each time used. Do the blade guides align properly after adjusting. Does the unit run smooth and vibration free when underway. The issue becomes does changing a setting for one part effect other areas of the machine and cause you to "chase your tail" to make it all work correctly. So many little details to worry about. All of the manufacturers have "Tune-up" settings to compensate for a lack of tight tolerances during manufacturing. Some do it well and others no so well. Most of the manufacturers source their products from the same production facility. Just look at the designs between them and you'll not see them to be any different. If your unit is going to be in use a lot then give high consideration to one with a brake, it's a real time saver. Blocks vs bearings for guides, it's a big debate and you'll find opinions for both, good and bad. I bought a Rikon 10-326 and wish I would have stuck with my old Delta 14" with riser block and "Carter" upgrades. I would have bought a bigger motor and been happier. Carpe diem my friend and good luck.
I have the Rikon 10-326 and have been very pleased. I've resawn up to 10" so far and it has plenty of HP. My one complaint has been getting the table and the fence aligned properly with the blade. It's a bit fussy on both counts.
