I have a FEIN 9.55.13 vacuum that still runs great and I would like to use it with my new Festool TS75. Do any of you connect a FEIN 9.55.13 vacuum to your Festool TS75 . Is there an adaptor that I can use so I can connect my FEIN Vacuum to my Festool TS75?
I have a different Fein model (9.77.25) than yours. It has a 2 1/4" vacuum port. If yours has a 2 1/4" vac port, you may be able to use Festool's green 1 3/8" +/- vacuum hose to connect the two together. I use the green hose to connect my Domino to the Fein vac. The fitting at the end of the hose that fits into the vac is 2 1/4" also. Works perfectly. I'm not sure what port size is on TS55. If its same as Domino then that's one solution for you. I actually really like the green vac hose. It's really flexible and fits many of my other non-Festool portable power tools.
