what is a good way to build a router fence. just made a table for mine ty . new woodworker.
I started my last fence with a piece of 3" aluminum angle. My first fence was stacked 3/4" birch ply. 2 pieces 2" wide under 2 pieces 1" wide (that gives me clamping area) that run the width of the table. . One is 35 yrs old and the other less than 1. Use both. 1/4" router in old one and 1/2" in the other. Still have some 1/4" bits that I haven't broken yet!
Joe
A few years ago I tried every aftermarket fence I could get my hands on. I finally built mine from 4# square aluminum tubing with a UHMW face. Each end of the tubing is plugged with a phenolic plastic square 1/2" thick with a hole for vacuum attachment. The entire fence is indexed with one of the original Incra Jigs which has served flawlessly for 10 + years. Before you spend a lot of time or money on a router fence, watch a few episodes of the Router Workshop on cable/satellite TV. Those two guys have a very different approach to fences and jigs which is frequently very instructive. Good luck. DocK
thanks for the info. but we cant get that on tv here in ontario canada.
The show is produced in Ontario, Canada, and you can't get it there?
I have a Incra fence that I just LOVE! All the gagets on it..
Nice for some special things but ...... ANY ..... fence that is a true 90 degrees to the bit is more than you need for most work..
