What is the Fibonacci series?
I understand it can be used instead of the golden section for determining cabinet dimensions, but I am confused on exactly what it is and how to use it.
I would be grateful for any sage advice from any of you who are familiar with using this series and can explain it to me.
It is a series of numbers any two of which add up to the next number. For example: 1-1=2, 2-3=5, 3-4=7 etc. I know of no application to the Golden Mean, which is a ratio of 1:1.618 or thereabouts.
Assuming that the sequence starts 1, 1, 2,.... then the ratio of two terms, the n+1th term divided by the nth term is a pretty good approximation to the golden ratio. In fact the limit (as n goes to infinity) of these ratios is the golden ratio. The n doesn't have to be too large. For instance 8/5 = 1.6.
http://www.mcs.surrey.ac.uk/Personal/R.Knott/Fibonacci/fib.html
Fibonacci series is that each number is the sum of the previous two.
1, 1, 2, 3, 5, 8, 13... etc.
This series can be employed as a method ofr pleasing proportions when designing furniture ('Shaping Wood' by Lonnie Bird pg 37)
He also illustrates the Golden Mean of 1:1.618 and Hambidge rectangles based on arcs drawn from the previous sized drawer.
It is an interesting book I got from the library. I might even buy this one.
TomS
I understand now that the series is built on the sum of the previous two numbers, but how do you start?
For instance, if I am going to build a dresser, how can I use the Fibonacci series to determine height, width, and pleasing proportion for, say five drawers of different heights?
Start the sequence with whatever dimension you like. To an example (a five-drawer "pyramidal" chest), make the first width dimension any size you like. Let's call that dimension A. In a true Fibonacci series, the second drawer would be the same dimension (but let's give it a different name and call that dimension B). The third drawer would have dimension C, which is the sum of A + B. Drawer four has dimension D, which is B + C, and drawer 5 has dimension E, which is C + D.
A crude graphic:
A |----------|
B |----------|
C = A + B |----------|----------|
D = B + C |-------------------|----------|
E = C + D |------------------------------|--------------------|
Obvioiusly, you could turn this "sideways" and use the dimensions as depths instead of widths. I just couldn't find a way to make that look good on a posting :-)
Make sense?
Edited 4/7/2003 2:08:14 AM ET by MarkH
Edited 4/7/2003 2:08:36 AM ET by MarkH
