Hello Everyone
Just discovered that there is form on this site!! And boy can I use some help right now…
Just finished building my wife a new kitchen table. It has a ash top and I made the legs and skirts from some quilted maple. So now its time to finish everything. I remember reading an article in a issue of Fine Woodworking about finishing figured wood and cannot seem to remember which issue it was. Can anybody help? Please!
Any help is greatly appreciated.
Thanks ahead of time for any and all help. I look forward to using this form often.
Drew
An article by Jeff Jewitt on finishing curly maple appeared in issue 153 March/April 1999. I can't find or remember and article on finishing quilted maple, so this may not be the article you are looking for.
Thanks for the reply...I am now going to the basement in search of that issue.
Drew
Drew,
Dyes do a great job of "popping" the figure in maple. In this sample, I used linseed oil on the left, lacquer only in the middle, and a golden/amber dye on the right.
Linseed oil, Lacquer, & Amber Dye
Here's a closer shot of the middle and right sections. The curl has very nice depth (chatoyance, directionality, shimmer, etc.) with just the clear coats, but the dye gives it a more dramatic look.
Shellac/Lacquer vs. Amber Dye
Here's an easy, but very nice looking finish for figured maple;
1. Sand the wood to 220 grit and remove the sanding dust. Make sure the final sanding is by hand, in the direction of the grain, to avoid any sanding marks.
2. Apply dye (water reducible) to the wood with a brush, rag, roller, or by spraying. Use gloves. Wet the wood very quickly - do not let the dye sit on one spot longer than another. If you let a drip or run sit in a spot, that spot will stay darker than the surrounding wood.
3. Let the dye dry completely and then apply your topcoats.
Do samples using a color of dye you like. Try different ratios of dye and thinner to see which shade you like best.
Paul
Paul
Thanks for that reply, very imformative. I like the way the dyed section looks. But am wanting to just give the maple parts a natural color and color the ash top and trim on the table.
But I do have more of the maple around for more projects so intend on using your method of finishing.
Again thanks for the great reply.
Drew
