Hello,
I’m hoping someone can make detailed recommendation for an appropriate set of files for working steel for scratch stock. I’ve used my Lie-Nielsen beading tool on several projects, but would like to make some custom profiles. Before putting money into additional files for metal working I’d appreciate some guidance. Most of my files are ones I use in woodworking, so I’m not very familiar with the type of cut or coarseness that I should choose or if it is appropriate to use wood files on steel or vise versa. I’ll at least need some type of tappered round file, triangular, and flat files. Thanks for whatever suggestion you can make.
When I make a scratch stock I generally use pretty simple files- You are in luck- you really don't need much- Obviously it depends on the profile you are going for. Round profile to scratch a bead is easy- go to the hardware store and pick up a chain saw file that is the right diameter.- other files you might use would be a flat file- 8 or 10 inch, single cut mill bastard and a triangular file (the same as I would use to sharpen a dovetail saw which is a 5" double extra slim taper. Like I said- it really depends on the profile- the good news is that everything is usually pretty easy to get at any decent hardware store- if that is not an option then places like Mcmaster Carr, Grainger or MSC all carry them.
Sometimes you do not even need a file and the whole thing can be done with a bench grinder.
Good luck- I am glad to hear that you are willing to make your own- bandsaw blades (large resaw type), card scrapers and old hand saws (like you would find for a couple bucks at a tag sale) all are great sources for the steel you will need.
Bob Van Dyke
