I am having trouble with getting a filler (for nail holes and a couple of bad spots) dark enough. Any suggestions?
This is a very dark stained piece (Bartley) with lots of molding, hence nail holes that show. It will have a semi gloss lacquer finish
Chuck
This seems like a natural for stick shellac. First put on a coat of the top coat, so the color will be set and then select the appropriate stick (or sticks). They are available all the way to black I think, so you should find a pretty close match, and they can be mixed.
Few wood fillers do a good job when it comes to taking stain and matching the color of the wood. I've had the best results when I've used those wax crayons, or the putty-type fillers, after I've stained.
They come in many colors and can even be blended if necessary. After my stain has dried, I go over the piece and fill the holes, etc with whatever color(s) will give me the best match. I smooth it out (sometimes with a screwdriver blade) then apply my finish. Most of the time, the filled spots become virtually invisible.
I've never done this with a lacquer finish so I would recommend practicing on some scrap before you go for it on a finished piece. It works fine, however, with poly finishes.
you can use a sharpie to darken it, then use a stain marker to blend it in
