I have some old Doug fir timbers; that I want to make a rustic table with. The pieces are checked and have cracks. My question is: How do I fill the cracks; so they look good. Is epoxy the answer?
Thank you
Thank you
Checked lumber will only get worse. Filling the cracks with epoxy is a stop-gap measure likely to fail in the long run. If the checks are on the ends of the boards, I'd cut them off and burn the scraps in my wood stove. In the middle of a timber, the conventional approach is to treat them with a butterfly.
Dovetail butterflies and epoxy. Since it's a rustic table, a few smaller checks won't matter too much. Before butterflies were cut, I'd squeeze the check together with a clamp just a bit, to put some of the pressure on the butterfly.
I have used epoxy for this same purpose, with the end result being that I was building rustic furniture.
I prefer to fill with the epoxy, then joint 1/32 off the surface to get my finished face.
I wouldn't clamp the board together first. The epoxy is just a filler, not a repair.
Hal
http://www.rivercitywoodworks.com
