Hi,
This birds eye maple burl I have is already to be finished. I had it
power sanded, and it is beautiful. It is over one hundred years old
and 4 inches thick. Anyway it has a few cracks. A couple are kind of
hair line, and one is about an 1/8 inch. Any suggestions how to fill
them, and should I stain it before or after I fill. Thxs.
Patt.
Patt, Maybe I'm fishing here, maybe there is a better way but I always come back to this question: got any of the sawdust left over after the sanding? So many times I have tried other fillers, and different so-called solutions, and I have always come first full circle to the sawdust/glue filler method. Just finding the right mixture with enough sawdust to work with is the trick, or has been for me. Good luck.
*One step better in the sawdust catagory is to make a paste filler using fine sanding dust mixed with the intended finish. Using glue with sand or saw dust will not allow for coloration caused by the finish, and in nearly all cases, stick out like a sore thumb. If you intend to stain the burl(I wouldn't), use a dye stain, and dye a pile of the sanding dust also.
*Dave, Your're right, I had that thought try to enter my mind, but didn't pursue it for some reason and didn't put it down in some readable form for my answer. Thanks, Bill
*Patt,You do not mention what the piece is and it's design. I do agree with Dave's clarification however, an eighth of an inch is very significant. The use of fillers or "dutch mans" will not obviate the defect.Perhaps a designed inlay could be used to "eliminate" the defect?Dano
*Patt,If the burl is 4 inches thick use a plug cutter and cut some burl plugs from the bottom, then drill appropriate sized matching holes and use the plugs to fill the voids.Stephen
