My finish is Waterlox gloss. I used abralon disks to remove
rough spots and level. My final steps were with auto polish
applied with my oscillating Bosch sander. I suspect a better method
would have been to use a rotating polisher at a higher speed like they
do at auto shops. Am I right? The oscillating sander seems to have left
those funny swirly like marks on the finish. I want a high gloss and
what I ended up with is more satin. Any suggestions will be appreciated
especially recommendations of the appropriate type buffer.
Ken
Ken,
Did you take the Abralon through the grits up to 4000? Did you use a worn 4000 pad and a little water for the polish? The "Surbuf" pad is an option for polishing with a random orbit in place of the Abralon.
By the time you get to polish, there shouldn't be any visible swirl marks.
Paul
Paul:
Yes I used the grits to 4000. I spoke to Waterlox
and they suggested the product is best left as is
and suggested if I'm disappointed to re-coat. The finish
isn't bad and feels great to the touch but I'd prefer the high
gloss it had before the rub-out. What kind of polisher is best
orbital or circular?
Thanks.Ken
Ken,
Using a random orbit sander for rubbing out is fine, it's just slower than a high speed buffer and you don't run nearly as much risk of burning through or melting the finish.
I understand why Waterlox doesn't really recommend rubbing out their varnish; it's not nearly as hard (brittle) as lacquer, shellac, or a short oil varnish (like Behlen's "RockHard). It's kinda soft for the rubbing process. If you let it cure for at least a month, it will rub out better than it does when it's "fresh."
Paul
Paul:
Thanks. I did let it cure for a month. I think I'll clean
the polish with ammonia and water like the Waterlox
advisor suggested then re-coat. Maybe this time there
will be fewer dust spots.
Ken
I don't have any personal experience with Waterlox, and I haven't done a lot of rubbing on waterborne finishes. The ones I have worked with responded pretty well to dry buffing with a lambs wool bonnet on a 7" polisher running 1100 or 1200 RPM. Speed and touch are very important because you have to generate enough heat to make the finish flow a little bit, but not enough to make it burn and catch. Practice before you try it on good stuff, and always keep the rotation running off of edges, not into them. When I polish, I generally let only half of the disc contact the surface so I can control the direction of the polishing stroke. I only tilt it a little bit; tilt too much and the edges will burn.
Anything that gives you the right speed should be OK. I haven't been very happy with the results I've gotten trying to polish anything with a RO sander, even with Abralon, but I do know pros who say they get good results. Maybe it's because I have lots of practice with a straight line sander and a buffer and am more used to it.
Michael R.
Michael:
Waterlox is a tung oil finish. Are you saying I can buff to
a high gloss without using a polish? Any thoughts on the
Milwaukee polisher-sander?
Thanks Much
Ken
Oops! Well, there's no point in being ignorant unless you show it once in a while. At least ignorance is curable with a little effort.
I have had good results dry-buffing softer finsihes as I described. I don't know whether it will work on Waterlox, but it might. In my experience, soft finishes will only polish so far with abrasives. After that point, dry buffing will heat the surface just enough that the scratch pattern on the surface flows together and gives you a higher polish. Worth a try in my opinion, but practice on scrap before you try it on the good stuff.
If you are a pro, I could recommend a lot more suitable finishes for a bar top, but they are not really suitable for occasional finishers.
I have a 7" porter cable variable speed right angle sander / buffer that I paid about $220 for if memory serves. If you are going to do much polishing a variable speed buffer is a good investment. I think Milwaukee makes a similar unit, and their tools are generally quite good. Makita makes one, too. I'd just buy the one you can get the best price on; I don't see much difference among them.
Michael R.
Michael:
I will definitely take your suggestion seriously.
Thanks Again
Ken
I thought this thread had something to do with the demise of Luca Brasi.
