my grandson is making a minecraft box (see photos). it is a cube that opens with a brass piano hinge inset in the back. it is about 28″ on each side.
the frame is solid walnut. the sides and top consist of 1/4″ thick squares (of sapele, maple, alder, cherry, oak) glued onto Baltic birch plywood.
there are some gaps (up to 1/16″) between the field squares and the walnut frame.
he wanted to keep the finish as clear as possible, so I was considering a blond shellac finish. after the first coat (doubling as a sanding sealer), I was considering a wet sanding (400 or 600 grit) of the second coat of shellac to fill in the gaps (see the photo). then another two coats of blond shellac.
another option I was considering was use of watco danish oil in a similar fashion.
what do you think?
instead of the first coat of shellac, should I use a separate sanding sealer (if so, what brand)?
what ‘cut’ of shellac should I use for the first and subsequent coats?
will the wet sanding blunt the whiteness of the maple?
would you use a different finish?
would you use a different method to fill in the gaps?
I don’t have experience with varnish (but willing to be taught by you if you think that would be the best finish). I don’t have a sprayer, so the finish would be ‘clothed’ on or brushed on.
thanks for your advice.
Great piece of work there.
If it is to be used for anything, I would use a water based GLOSS polyurethane.
Apply a 20% thinned coat of the product, then sand and apply one or two more coats of the full strength products.
If you want a matte finish then you can either rub it over with 000 steel wool and wax or apply a final coat of satin finish water based poly.
This finish is very tough and will protect against most splashes, though not dings and dents.
Shellac is a very quick finish to apply and could be used in a 1lb cut as a sanding sealer before most any other finish. Personally I love it but poly produces as good or better finish and is way easier.
great advice. thank you much.
