Still working on one of my pandemic lockdown projects-learning how to cut dovetails.[the other one was reorganizing my shop. not sure which was harder]. I have been making a modified version of a serving tray plan by Chris Schwarz [excellent for learning how to cut dovetails!]. I have made them from cherry, pine, and chestnut. Now I am using ash. Any ideas or suggestions on how to finish ash? I normally use shellac and wax, but the surface feels like corrugated cardboard. Not a formal piece so I don’t want to get into grain filling.Sanding to 220. Help. tomerutkowski@gmail.com
I’ve used Armr Seal with great success.
Do not try a water based dye stain. The pores are of a size that the stain fluid is trapped in suspension preventing the stain from actually getting on the ash. There will be pinpoints of unstained wood.
I needed a dark walnut color for certain parts and ended up using a gel stain successfully.
Ash and dovetails, that much have been fun chiseling. I made a Roubo frame saw from a Blackburn tools kit and used ash. I didn't have the washboard issue you described. I finished it with blond shellac and wax and was happy with it. Then again, I like shellac over all other finishes unless extreme wear is a concern.
I'm a water based poly fan. I usually use a gloss then apply wax with 00 steel wool to even out the sheen level.
Parts of my moxxon riser are ash. I used Watco danish oil on it. Never really thought if it as "finishing", but it looks and feels pretty good.
