Hello All, I recently purchased a butcher block countertop and wondering what I should use to treat the wood. It’s for a kitchen island. We wont be cutting or eating directly on the surface so just looking for some opinions. Thanks!
You have lots of options. My faves for an island would be tung oil or osmo. Both spot repairable and easy to use. Both resist spills. Osmo will cure a little faster. As an added bonus, both are food safe.
One thing, tung oil won't darken the wood. I prefer pure tung over Osmo, but we all like different finishes.
Mikaol
When you say "butcherblock" is it endgrain or "bowling alley"?
I think it's endgrain. Bought it from menards.
Bowling alley. Long grain, not end grain.
I've heard that soaking in a tub of mineral oil for a week works...
In the kitchen it will get wiped down wet and be subject to spills. Tung oil will absorb a bit and can be built to a film finish. I'd suggest getting to an "almost" film finish to allow for renewing it easily. Any finish will darken the wood a bit, so test on the back. Tung oil comes in colored formulations if you want to add a tone.
So, no cutting or eating, but likely getting wet, scratched, and hot things put on it? I'd be looking for something more than an oil finish.
I use Boos Block Oil on my maple counter top at home.
https://www.johnboos.com/care.asp
I built a large kitchen island out of maple and didn't need to use anything nouveau or exotic. Give you new top a good sanding to at least 180 grit in order to get a smooth consistent surface. I used several coats of a good polyurethane which provides a tough water resistant easy to clean surface. The island top has been in place for seven years and absolutely no problems and still looks great. When I do need to refinish it I will just sand it a bit and put some more coats of poly on it. You can pick the kind of sheen you want also.
