Howdy, I’m new to woodworking and I could use some help about what finish to put on a cherry fireplace mantle shelf. I was thinking of using Sam Maloof’s poly/oil. Would this be a good finish for a mantle. I’m open to any type of finish. Is there a special type of finish for mantles? Thanks for any help. Garlin
Garlin
I use General Finishes natural, with 4 coats of Crystalac sprayed over after a couple of days drying time, with excellent results. It's a hard, durable water based finish that you can expose to reasonable heat, drink glasses, candle wax, etc... and not have a problem.
Garlin,
Welcome!
I don't think Maloof's, which I use and really like, is the right finish for a fireplace mantle, particularly if you intend to burn logs. I think the finish will discolor since the pores are not really as well sealed. Since Maloof's would give you a very subdued satin finish, I would suggest using several applications of boiled linseed oil ("BLO") or tung oil, followed by a stain polyurethane after the BLO has cured - at least a week. You can also use the Maloof's but after it has cured, follow up with a straight poly top coat and buff to a desired sheen. Others may have some different suggestions. If you use BLO, be very careful to safely discard your rags since it is highly combustible.
Doug
See the post in the Finishing section on ploys: http://forums.taunton.com/n/mb/message.asp?webtag=tp-knots&msg=23190.1
Edited 4/18/2005 6:08 pm ET by Doug
Thanks for the advice. I think I'm going for the polyurethane topcoat as you suggested.
