Any recommendations on how to finish lacewood to enhance the great ray fleck? (PS. I’m making boxes, business card holders, etc. so the finish has to be only moderately tough–mainly it has to look eyecatching.)
Jim Bell
Jim Bell
I have used a tung oil blend on a few different lacewood projects. (3-4 coats for a rich depth) A thin coat of wax after that will help if you like a bit more sheen.
Sure pops the rays and flecks
Dave
Thanks, Dave. Have you--or has anyone--ever tried what is sometimes done with figured maple--yellowish aniline dye, boiled linseed oil, and then a clear top coat?
Jim Bell
Dave exactly.. About what I do.. I use Lacewood (I think') every stick I get looks different so not sure... but a well established supplier so I sort of believe them..By the way, it is a REALLY strong wood, and 'sort' of easy to work with.. To bad I get a rash from it.....
After your oil dries you could use the Beall Buff system which turners often use . There is a Triopli like compound, a diamond compound (talc?), and a final buff with canoba wax. There are buffs sold for the lathe (disc shaped) or for a drill press (round). A high speed (about 3500 rpm) is necessary especially to melt the canoba wax. I use it for small projects such as boxes (square and round) and picture frames, crafts, etc It is fast and it gives a spectacular effect.
