Hello All!
I’m making a little coffee mill for a family member for Christmas. I have no idea how to finish it.
Some water protection is necessary (kitchen counter). Ease of repair of finish isn’t really a factor. Nor UV. Ease of application is a biggie. I need it to fairly straightforward to increase my chance at success.
The picture shows the lighter colored top and bottom pieces in the foreground, also the sides and front and back. The birch for the drawer is in the background.
The drawer sides will be half-blind dovetails into the walnut drawer front.
Any help is appreciated.
–jonnieboy
Is it black?
Hi Gretchen.
I don't know what type of walnut it is. Whatever it is, they make caskets out of it. Much help, huh.
I'll bet I can get a postive ID today. I'll try.
--jonnieboy
Ummmm......might be showing my ignorance, but is there any commonly-available domestic walnut other than black walnut?
Jonnieboy,
Do you have any finishing product in you cupboard to test, or do you have a favorite form past experience? It can help if you have enough wood to be able to make a test strip.
I am sure some of the more knowledgeable poster will give you better advice, but I'll jump in and point you to the wipe on poly products.
That should be the easiest route to a nice finish that offers reasonable protection. I have not worked with walnut so do not know the best for that species.
Don
Don,
For some reason I have what seems like 55 gallon drums of Danish Oil. Not sure how I got that much.
I have some of the following:
clear and amber Zinnser's shellac
Varathane Classic Clear Diamond Wood Finish (Gloss)
Pratt & Lambert Varmor, Clear FinishSatin
Cabot Satin Poly
BLO, Mineral Spirits, Den. Alcohol
I was thinking of BLO and Shellac.
Or, can I thin the Satin Poly with MS or BLO and wipe it on? That might be a good one.
I'm definitely doing test strips.
--jonnieboy
You want to use something that will not compromise the flavor of food/the coffee. I think it may need to be shellac, and protect from getting wet. Actually, I have heard that if you use totally unwaxed shellac, it is VERY water resistant. I don't think you can use anything with oil in it. It needs to be neutral.Gretchen
I use dewaxed shellac as a resist on steel when I etch it. I can attest that shellac is very water resistant. When I etch, the steel may be in a salt water solution for up to half an hour, sometimes longer. There is some pitting at those times, but not much. It still takes a good deal of effort to remove the shellac when I've finished.
Jon - you got what you need? lemme know you need any other free advice.
Kent
jonnieboy,
If it's not going to get constant soaking at the sink and a few drops of random water will get wiped off in a reasonably quick amount of time, I would suggest BLO finished with shellac on all the exterior parts NOT touching food. BLO won't hurt the food -- just smells forever in contained areas. Shellac or bare wood only on the hopper and on/in the drawer as any BLO will leave a lingering smell on the beans.
Quick, easy and not hard to apply. If it's for Christmas, do the BLO immediately so it has time to dry at least 2 days. The Shellac only takes a few minutes. Waxed or not, Shellac is pretty water resistant.
If your going to put on an additional finish over the shellac, then use unwaxed only.
If your not concerned with bringing out the color and depth of the wood with BLO, then a straightforward wipe-on commercial finish will be fine
BB
Boiler and Gretchen,
Where do you live? I'm going to pop on over to your houses and plant a big wet kiss on each of you.
Aw heck, the roads are still bad from the storm. Can it wait until spring? I owe you one.
--jonnieboy, "Romeo Shellac"
Glad to help.Now we have to talk about how long to roast your green coffee beans for your grinder :)http://www.sweetmarias.com/index.htmlBB
Ohhh yeah. Something for inside the mill! I'll be looking to you for recommendations on that one.
-Jonnieboy
With all due respect to boilerboy, I just would NOT use any oil of any kind. It isn't that it is dangerous, but coffee is a VERY sensitive taste and you want nothing to interfere with it.
And as I often say, this advice may be worth exactly what you paid for it. But you're welcome--I'll take a little kiss from any gentleman, which I am sure you are!! Good luck.Gretchen
No oil inside drawer. Got it.
-jonnieboy
Gretchen,No offense taken but as I thought I indicated with "BLO finished with shellac on all the exterior parts NOT touching food" meant no oil on food contact areas which is to say, all interior parts, the hopper, the grinder chute and the drawer. Perhaps I wasn't clear enough.Shellac on the inside of the grounds drawer, perhaps but that is for ease of cleaning. Finish isn't really required there either. BLO on the outside show areas won't influence the taste of the grind especially for the relatively short time the beans go through the process.Boilerbay
Oh, I think finish inside may be necessary. I don't know what odor/flavor raw black walnut might lend to coffee either. And the sides of this look pretty thin. I am not comfortable with oil on it at all. BUT it is all sort of an unknown.
The best course might be lining the inside with 'something" as a complete barrier. Mylar? Gretchen
Hello Gretchen,
I am with you in this one. Also, and you would know more about this than me because you may have delt with more antiques in your line of work, but wouldn't there be some kind of tin liner in these, kind of like in a tea caddy?
