I am making some solid walnut bookshelves and want to finish the shelves appropriately, but aree not sure what to use. I usually use a laquer finish (Deft), and probably will on the case, but think it might be too soft for the shelf itself. One article recommended shellac. Any suggestions from you who are experienced with this? Thanks.
I've just finished a walnut dest with two coats of boiled lindseed oil followed by three coats of orange shellac. I'm very happy with the result. Best of luck.--Chris
Lacquer and shellac have a lot in common. They are both very hard (brittle) finishes though not very durable. Their hardness is the reason they are both good candidates for a high gloss finish. Both cure when the solvent evaporates and both have 100% melt-in when new coats are added.
Straight varnish is more durable and is a good choice in situations where wear, heat, water, and hosehold chemical resistance is needed.
Personnaly, I'd use lacquer on bookcases. It's very easy to scuff sand and apply another coat if needed.
You may want to try some other brands of lacquer besides Deft just for comparison. Sherwin Williams has a selection as do a great many other suppliers.
Paul
F'burg, VA
Thanks for your advice--since I have the laquer and the equipment to spray it, laquer is probably my best bet.
