Peter, I have been making some shop accessories ie: drill press table and a wood cabinet drum sander etc.. I have made most of these cabinet grade birch plywood and fir plywood and am thinking I should apply a protective finish on some kind. Any thoughts on what would be applicable or just leave them alone. Please no comments on the Oilers this year.
Best Regards
Kenne
Keene,
First off, I would suggest you make a drill press table out of something solid like hard maple. I would leave it unfinished as it will have holes drilled in it at some point.
Concerning your other cabinets; You could leave them raw; a coat or two of shellac sure wouldn't hurt either. A slick surface just cleans up a little quicker. If you do shellac it, just give it a light sanding after each coat and it will shed dust easily.
I won't say anything about the Oilers if you give me the same consideration with the Rangers. BTW, Chris Prongers team seems to be doing quite well.
Keep in touch,
Peter
Thanks Peter and you have a deal on hockey team performance.
Regards
Ken
