I am completing a cabinet and I am at the finishing stage. The cabinet is a combination of poplar and birch plywood. I anticipate a final painting in a flat black to emulate the chinese type cabinet. My question is whether I should first apply a coat or two or three of diluted shellac to fill the pores and to give me a smoother finish. The technique I use when refinishing furniture is to apply the shellac and then a varnish sealer. Also since I am anticipating painting this piece in flat black, does it make a difference whether or not I use clear shellac or amber? I also would appreciate any comments on the final application of flat black – that is spraying vs painting? Thanks
Hi.
I'm not an expert in finishing. Can I recommend Jeff Jewitt's site:
http://www.homesteadfinishing.com
Jeff isn't perfect and has his 'naysayers' but he answers most, if not all, the questions posted on his very-popular website and seems to be very credible.
I'm certain that others will recommend good resources as well.
lp
Thanks for the infor. ewe33
When I paint or use pigmented lacquer on furniture, I always start with two coats of Zinnser pigmented shellac sealer. I put the first coat on heavy (spray application), let it dry, and sand smooth with 220. I don't worry about sand-throughs as I plan to spray a second coat. If the first coat reveals any unwanted seams, holes, dents, etc., I fill those after sanding and sand the repairs level. I then spray a second coat of the Zinnser, let dry, and sand smooth with 320. The Zinnser pigmented shellac sealer gives an even base color for the paint, seals in any potential bleed-through problems, and sands very easily - to me it can't be beat.
As far as the black goes, if you can spray - do. It's faster and easier (IMO). Sherwin Williams has some good furniture grade paints.
Paul
F'burg, VA
Thanks for the imput it was helpful. I think I have decided to do just that. Ed.
