Hello Peter,
I am replacing rotted sections of an old, exterior beadboard soffit with new mahogany beadboard planks. The planks will sit under the eaves, and so receive no direct sunlight. The roof was recently replaced, so there should be no concerns about leaking from above.
I’ve read Sean Clarke’s recent article on exterior finishing and, although the epoxy sealer sounds great, I don’t like the idea of using a spar varnish. It will be difficult enough installing the beadboard two stories up, and I can’t imagine setting up scaffolding every 18 months to re-sand and re-coat the whole surface. I’d like a finish that doesn’t need to be re-sanded.
I thought of using the epoxy sealer followed by a Waterlox Marine Finish (Waterlox says no sanding is required before seasonal re-coating). I’ve also read about the Penofin Hardwood Finish, which requires no sanding for a re-coat.
I’d be really grateful for any suggestions you may have. I am certainly not committed to the epoxy-Waterlox combination.
Thank you,
Lucian
Another edit: I just realized that an oil finish wouldn’t work over epoxy. So now I’m really confused.
Edited 9/19/2006 12:35 pm ET by Lucian
Edited 9/19/2006 1:06 pm ET by Lucian
Lucien,
With due respect to Mr. Clarke, I wouldn't do an epoxy on anything that wasn't very easy to access. If or when it fails, it is not an easy problem to rectify.
I would consider using a penetrating oil made for exterior work. Cabots, Olympic, Sikkens are a few that come to mind. An easy way to apply them is to use a garden sprayer. Pour the oil through a paint filter, pump the pressure up and you're ready to go.
If you have to clean it, again using a garden sprayer, use a combination on TSP and bleach, spray it on the boards and then hose it off. Let it dry well and reapply your oil.
I do this on the cedar siding of my barn and it works very well. I have no hand work (sanding) with this method. This would be my prime consideration if I was working overhead.
I only use clear oil.This way I don't have a problem with matching.
If you use this method, keep one sprayer dedicated to the oil. Just be sure and flush it out well with mineral spirits when you're done.
Peter Gedrys
