We have bought a house which still has the old wood flooring, circa 1850, with 1 foot wide planks. Can’t be too sure what wood it is-not pine or oak. Condition varies but there is no paint on it except for a staircase, just a lot of scratches etc. My initial thought is to give it a light sanding but I’m not sure about the best finish. Should I avoid polyurethane? Thanks for any help. One staircase has been painted and I would like to remove the paint. Assuming its got lead in it, is it sufficient just to wear a good mask with appropriate filters and vacuum well afterwards.
Tnarg,
I would just wax the floors and test for lead on the stair paint. If there is lead in the paint, you need to be a lot more careful than just a mask...including desposing of the chips,etc.
I'd swear that I got a tightly focused and strong headache from sanding a couple of floors in my 150 year old house. It was when the exact same thing happened the second time I rented a sander that I associated it with the sanding.
I'd certainly want to keep the patina of age and wear so I wouldn't sand the floors at all
I'd rent a floor buffer and go over the floors thoroughly with a coarse nylon buffing pad, then I'd finish them with a penetrative oil finish.
As to the stairs, the paint could very well be lead-based and if so, sanding or stripping with heat are out. There may be regulations governing its safe removal and disposal in your area -- and penalties for non-compliance so I would check it out before starting.
IanDG
Serious question here, even if the answer seems self evident to you:
paint could very well be lead-based and if so, sanding ... (is) ... out
What is wrong with sanding? The lead paint problem doesn't have the reputation of asbestos. I was intending to sand a couple more rooms here, and that is why I am interested. Very interested.
My technique is to start with a rented drum floor sander to remove the paint. I prevent airborne dust from traveling to other rooms, which I would do whether or not concerned about lead. All dust in the sanded room gets removed from all surfaces - floor, walls, ceiling - by vacuuming followed by wiping every square inch down. The only difference this time was going to be getting myself a proper mask or respirator.
See anything that seriously bothers you in that approach?
Ed
All lead removers in MA must be certified. Perhaps you have seem them on TOH....with their respirators, disposable clothes, covered head to toe, in sealed off rooms. Clean-up has to follow a specific protocol to insure cross contamination is avoided. Is all this a little overdone? You bet...now, If I'm your neighbor and I have kids.....whole different story
BG -I'll check into local regulations. I am unaware of any regulations, but I can't imagine MA having tight rules and us having none. On the other hand, a guy near me had his 150 year old house stripped of paint by one of those "sandblast stripping" companies and I didn't see any tarps on the ground or anything else that indicated some steps were being taken to control the lead dispersal.
Ian - My wood floors were painted, so that is why I am sanding. Maybe I got mistaken for the guy who started this post, he's the one with the unpainted floorboards.
You'll have to check the regulations where you are regarding lead paint, but generally any process that will release lead particles into the air is not allowed.Maybe I misunderstood your first post but I thought the paint wasn't on the floor. I wouldn't sand the floor, but that's because I would prefer to preserve the surface patina and have the finished floor looking like a 150 year old floor that's been well maintained, rather than looking like a new floor.IanDG
