Finishing problem with ash. Want to end up with a fairly dark redish brown that will hid the grain. The grain is a particular problem on the turned legs where the grain is emphaised by the turning. Any suggestions
I don't know the full answer here, but I'd first experiment with getting the dark color using a dye rather than pigmented stain. The dye will color both early and late wood about the same. End grain could still be darker but on turning where you can't readily put a washcoat only on end grain, that may be inevitable.
Pore filler is the usual solution when you want to hide the grain on an open pored wood like ash. I'd seal the dyed wood with a washcoat of dewaxed shellac before applying the filler. The pore filler could have pigment added so that it colors the pores to the same shade as the dyed background. But it is a PITA to use on turnings.
