I am refinishing some walnut lamp bases from India. They have bands of intricate carving. I have cleaned off what remains of the old wax finish and applied three coats of tung oil, steel wooling between each coat and using a toothbrush to get the oil into the carved areas. Now I am wondering if I should wax the bases or leave them as is? I live in Colorado so dryness is a big problem. If I do wax them how do I apply it to the carved areas and how do I buff it? I would like a rich sheen. Open to all suggestions.
I know this was asked a long time ago but I run into this problem regularly. Depending on the level of detail, that is, complexity of the carving you would be wise to wax only the flatter parts of the carving. I speak from experience having tried --many times-- to get into all the nooks and crannies and having spent enitre days trying to blend and polish. To me, many times, it's not worth the aggravation. If you do brave it, try a nylon toothbrush covered with cloth and continually move to clean cloth.
*Try a shoebrush, or use traditional polisher's brushes from England or France. I don't have a source for them handy, but you might Email Gil Hummer at [email protected]. He might be able to steer you in the right direction. He also distributes Fiddes and Kiwi-Bois, both fine wax products, along with other finishing supplies.Michael Richwine
*Mr. Richwine is exactly right. Use a shoebrush. I bought my Kiwi horse hair shoebrush at Walgreen's.
*What is the best finish for carved walnut? I made a smaller version of a victorian secretary with some carving and don't know anything about finishing.
