Anything to keep in mind when finishing Cherry? I have a conference table that I hope to spray with a Lacquer and was looking for any input anyone may have.
Thanks in advance,
Ron
Thanks in advance,
Ron
You should decide first if you want to apply a light coat of oil to enhance the grain (or in the view of some, bring out blotching). I favor grain enhancement but it is purely a personal decision (either you or the client).
Sounds like a pretty good idea. With that in mind, how long would you let the oil cure before you applied the lacquer?
Thanks for the tip
Found this site from a post in another thread. Has some pretty good info and lots of color images from different approaches. Doesn't go into "blotching" much though.
Spraying with lacquer strikes me as a very poor idea. Even the catalyzed lacquers are not quite up to snuff for conference tables. I'd use some wipe on polyurethane instead. Or I'd spray on a conversion varnish. I recently have been redoing a set of cabinets which were finished pretty much clear over very poorly selected wood (lots of sapwood streaks mixed with nice heartwood). I had great results with an airbrush spraying a tinted polyurethane to even and darken the colors and then overfinished with a poly clear to resheen. One piece that was completely unfinished had some issues with blotching stains due to the geometry of the raised panels and I'd wash coat that if I had it to do over but I made it look quite nice anyway. Usually cherry finishes include some toner or tinted topcoat work to even out contrasts a bit and oftentimes staining too (people are loath to wait for that great burgundy look that comes with age).
