What is the best method of finishing cocobola due to it’s oily nature?
If you want to use an oil varnish, get one that drys fast. Wipe the surface liberally with lacquer thinner to get the oil off. The thing you're looking for is that the oil doesn't seep back faster than the finish dries. Lacquer is a better option. Vinyl sealers work better on oily woods (same cleaning process) under lacquer, and they dry very quickly. Any slow drying finish you use without cleaning and sealing will likely cause you grief. Good luck.
" You are young, my son, and as the years go by time will change and even reverse many of your present opinions. Refrain therefore awhile from setting yourself up as a judge of the highest matters." - Plato
