I have new 6 panel 8’0 unfinished VG Doug fir doors. They’re beautiful, although there are a few lighter places in some of the panels. I was going to start with wood conditioner to make the lighter wood come out more uniform. I wanted to Watco oil, then polyurethane them. If I use the “natural” Watco oil, I feel like the light places won’t darken to the same shade as the rest. Should I stain the doors first or use a colored oil? If so, what color stain/oil is best for Doug fir? Also what is the best color wood filler (for nail holes, etc.) for Doug fir?
JB, I have built quite a few pieces of furniture and cabinets out of Douglas Fir, both vertical grain and flatsawn. A light staining will even up the colour a bit and even more so the darker you go.
However, Douglas Fir is a funny wood in that it darkens naturally upon exposure to light so much in the first 6 months to a year that it is hard to say which panels will be darker or lighter after that time. Most of the time if the stock has been selected with a bit of care everything evens up nicely and any differences become quite subtle. Unless you have some really yellow looking panels I wouldn't do too much beyond a half dozen coats of clear water based exterior poly. The oil based poly or spar varnish will yellow quite a bit and this coupled with the colour of the fir after time may be a bit too orange for your taste.
As for wood filler, if you are going the clearcoat method use something that will be the colour of the fir after it has darkened. It may look a bit odd right now but the wood will darken around it. In one of my earlier projects I used a filler that was the same colour as the freshly milled fir and after the wood had darkened all the places there were filler really looked odd.
Good Luck, David
*Try using a red oak stain and high gloss ploy. I just finished an aquarium cabinet and it looks fantastic. The light and dark grains really look great. I used black trim and it matches perfectly.
