I normally use Waterlox as my primary finish followed by a coat of paste wax. What is the best finish to use for the interior of drawers. Will the same finish work as well or would a plain wax be better. And why. I can’t find any references in any of the online subjects.
Also, after years of only hand cutting dovetails, I’m up again some larger projects and am considering a simple routerjig for through and half blind dovetails. Any recommendations based on what’s commercially available.
Jerry
I use shellac on the interior of my drawers, as it is quick and leaves no tell tale odor. I shellac, sand and wax before assembling the drawers, being careful to not contaminate the glue surfaces. This gives a better finish, and allows easy clean up of any glue squeeze-out. I would avoid any type of oil inside, because it will leave behind an odor, that will take a very long time to go away.
On the dovetail jig I'm of no help, like you have only cut them hand.
Rob Millard
Edited 2/7/2006 8:33 pm ET by RMillard
Shellac, or nothing, are the two most sensible finish choices (in my opinion) for drawer interiors. Oil bases finishes can contribute odor for an inordinately long time.
