How does hardboard take a finish, I have some panels to make and am out of 1/4″ MDF. The finished panels will be sprayed with a Fuhr #380 varnish tinted white, am using a Fuhr primer as well.
Any reason why I can’t use tempered hardboard? I know I should just setup a test piece and spray it, but I’m on a time schedule and am hoping someone can give me a quick answer.
I've sprayed 3/4" HDF ( high density fiberboard) with excellent results. Masonite should spray just as well, spray both sides ,back side as a sealer. If the back is not sealed the panel could possibly cup.
mike
Thanks a lot for the quick response. Perfect timing, I'm ready to glue everything up.j
