I am looking for detailed instructions on how to finish Koa. Thanks.
The finish you apply depends on what the project is and how it will be used. I'd probably select entirely different finishes for a picture frame and the handrail of a staircase because they will be subject to different uses; the selection of wood would be an important, though, secondary consideration.
Koa isn't different enough from other woods to warrant highly specialized finishing techniques - it's pretty, and pretty expensive, but in other regards, not unusual.
So what's the project you're interested in finishing?
-Jazzdogg-
Jazzdogg,
I was looking for a way to mount my Sirius Satelite radio in my car via the cigarette lighter. I wanted to use a nice looking wood (that I had in stock) and finish it nicely to complement the interior finish of my car, which is the Vavona wood in the VW Touareg (can be seen at http://www.vw.ca). So, I cut a piece roughly 1.5" wide by 1.5" thick by 5" long.
Using my drill press I drilled a 2" deep by 1" diameter hole lengthwise into the koa to insert the DC power adapter portion and a smaller hole out the side to run the power cable. Then I mounted the radio unit on to the koa and plugged it in.
I am very happy with the physical result i.e. supporting the radio in the car out of the way of controls and gear shifter but would like a nice finish so it blends in the car little while bring out the natural beauty of the wood.
After all that I would really appreciate any thoughts you might have on a finishing process.
JGI
I just recently finished a box to put pet cremains in and I used a danish oil followed by a couple of sprayed coats of shellac and sprayed lacquer. I'll try to send a pic of the results
Hobbs,
Sorry to hear about your pet. A tough thing to go through. I would love to see the results.
JGI
