Anyone have suggestions for the best way to finish lacewood? I want something that will pop the grain, but I don’t want to darken it any more than is absolutely necessary. Would super blonde shellac be enough, or should I be looking to apply something else before the shellac?
Thanks!
Go for it. The shellac works quite nicely on lacewood. Pops out the contrasts in the grain and shows it off quite nicely.
On small pieces I've used aerosol lacquer, on others poly. Try a sample piece and see what you like. A sealer coat of shellac might save an extra coat or two of the final finish material.
I just finished a Queen Anne table, pix below. The top only is lacewood. I hand planed the surface. then I sanded in a lightish coat of BLO with 320, wiped it. Let dry for several days. Then several cats of shellac, and thee coats of a gloss varnish, rubbed out. I was concerned that the shellac was not a good coice for a table top. This was my first pice with lacewood. Man is that stuff heavy.
Beautiful work!
S4S,
That's just gorgeous.
And so is the photography.
VL
Alan,
What's lacewood like to plane? Does it want to tearout much?
It is hard and heavy, with a finicky grain. VERY light cuts, with a very sharp iron, and a very tight mouth. I used my HNT Gordon smoother, and worked up a sweat. But, essentially no tearout.
Alan
Damn, that's outstanding woodworking and even better finishing.
Thanks. It was a fun build. Spent a bit of time on teh slipper feet as I had not done them before.
Tung oil and wax.
