I am about to finish a table top jewelry cabinet that is made of both birdseye maple and walnut. I was going to use Generals Wipe on Arm R Seal finish on the whole cabinet. I was wondering if there was any reason to consider treating the two woods differently, either before the wipe on, or instead of the wipe on finish. Thanks in advance for the advice.
Marc
Cheerycherry
I don't see any reason to treat the woods differently. Both will accept the finish you propose without any problems and neither wood has the type of pigment that will bleed into the other. Enjoy your project. JL
Marc,
I also wanted to mention that maple and walnut are the two classic woods used by people making chess or checker boards. I have done many, and there have never been any problems, no matter what the finish was. JL
Thanks for the feedback. I have done this before without problems that i could see, but wanted to check if there was something i was overlooking or any better ways to do this. Thanks again, i will proceed.. Marc
Enjoy. JL
Be very careful when sanding to no embed walnut particles in the maple and before finishing be sure to wipe ALL the walnut dust away or you can "stain" the maple. In my view maple looks good when fresh but darkens to an ugly orange/yellow color over time. You can help avoid this by using a water based finish. Oil based finishes darken maple instantly in my experience.
Arkriver
You are right. Oil in the finish will darken all woods instantly. To keep it as light as possible, applying a white shellac sealer first, or any other clear sealer, will insure that the wood is not coloured by the final finish. Over time the light will have an affect, so it is important to choose a finishing product that will react to light as we want it to. Some have better UV protection properties than others.
If you really want the light look, wash the wood with a mild wood bleach first, and then continue the finishing process. Experiment on scrapes first. JL
Thanks , if i apply a clear shellac or other sealer first, can apply the wipe on tung oil urethane finish over this. I would like to keep the maple as light as possible.. Marc
Yes Marc.
Just make sure that you scuff sand to remove the nibs( caused by dust and things that settle before the sealer is dry) on the dry sealer coat before you apply the final finish and you will have exactly what you are looking for. JL
But this amber maple is just the look I really like.
We all like differnt things and so it is. It would be boring if we all like the same things.
