Hello experts
I have recently purchases a teak slab dining table, as well as a teak root coffee table. They are both meant to be used indoors. Pictures attached.
They are yet to be finished by the supplier. They offer only the following finish option, 3 coats of Ekolac 1300 outdoor varnish https://asiapaintsingapore.com/water-borne-varnishes/
I would like the table finish to look radiant, and enhance the grain as much as possible.
I have been reading about finishes such as Osmo and Rubio, and how they provide a much more natural finish and add depth to the table.
Can i have some advice on
a) would the availavle finish (Ekolac 1300) achieve a result that i am looking for and
b) would Osmo or Rubio be a better option and should I insist for it?
Thank you
Any chance you can get ahold of offcuts and try some osmo and rubio? Also, is it possible the vendor can send you some offcuts with the finishes they use?
The challenge with teak is that it is an oily timber. This makes finishing a little more difficult than other timbers. It usually means the timber needs to be cleaned just prior to the application of the finish otherwise the oil from the timber can impact the finish. Personally, I would probably seal the timber before finishing with a shellac.
Your not finishing this table, the manufacturer is. Finishing is like science! While design style, types of wood etc. are all negotiable I wouldn't in my wildest dreams ever change up how or what I do or what materials I use to achieve a finish on a customer's recommendation. Someone on the caliber of a George Frank, I'm all ears! We can talk about sheen,durability but beyond that I'm going to get there the way I know works! I am a one man shop doing one off things, I'm pretty flexible. A larger shop or factory would be more resolute in their resistance to start experimenting with finishes. They have equipment set up to do what they do. Maybe, just maybe on a no guarantees expressed or implied basis and for a fee would they change up on your insistence.
Beyond that I pretty much stick to an oil finish on teak.
