I’m making a cabinet from pine, I have a primer to block the bleed from knots, but do I put the filler on before or after the sealer? The surface will be painted.
Thanks in advance.
Thanks in advance.
Both. Fill any spots you see before you apply the primer. Then sand the primer smooth and fill all the spots that showed up after you removed the sanding dust (from sanding the primer).
I like to use drywall spackle for filler under paint. Easy to work, dries fast, takes paint well.
Paul
F'burg, VA
Paul; I have seen the spackle squeezed out of the holes that it was used to fill by the expansion/contraction cycles of the wood. I prefer to use glaziers putty on quick jobs and acrylic gels with pumice fillers for high grade work. These fillers seem to have more adhesion and elasticity and to survive the expansion/contraction cycling.
Thank you, didn't want to screw this one up, it's in the living room
I make a putty/filler with liquid hide glue and the fine sawdust (wood flour) from the same species. It takes a several hours to dry but is a great filler/putty. You can also add calcium carbonate (whiting) to thicken.
Stephen Shepherd
http://www.ilovewood.com
