Hi Peter:
I just bought a plank of quilted cherry which will become a “Hankerchief Table” as I proceed. I want to highlight the quilted grain. How would you suggest I finish it? Thank you for your assistance.
MIKE EDWARDS
Hi Peter:
MIKE EDWARDS
Mike,
There are a variety of ways to highlight the quilted grain;
Give the surface a light application of a thin oil finish such as antique oil (minwax) or something similar. You could also use some boiled linseed oil. Apply either judiciously and wipe it very well to remove any excess.
Another way is to apply a dye first, then the above and then finish.
Another is to do a layered dye. Example; medium yellow followed by red brown.
Another is just to apply a finish such as shellac.
The oil treatment will darken it a bit and highlight the grain.
The dye first followed by oil will give it an inner glow as well as highlight the grain.
The layered dye will give you a deeper and richer glow.
Using shellac will show you the natural look and give it a glow.
Note; a purist will wretch at the idea of putting ANY color on cherry. Remember, it's your table so do what pleases your eye.
Be sure and make some samples first and finish them. This will give you a chance to live with the different looks in different light. Try and make your samples a decent size also. It's very hard to make a visual determination on a piece of wood that's three inches long (for example)
These are just a few examples. Experiment to get the look you are after.
Have fun.
Peter
