I have a question on finishing. I am building a bench that is a closed cabinet with raised panels on the front and sides. Red oak is the wood used. My question relates to the order of finishing and construction. A magazine article on building raised panel doors said to stain the panels before construction for wood movement. I knew that but wouldn’t you also want to apply the polyuerothene before construction for the same reason? Another question is if you stain the panels first, without applying polyuerothene, then assemble the bench, when you stain the rest of the bench you may get more stain on the panels while staining the rails and styles which will lead to inconsistent coloring. I know this has been done a million times before, just not by me. Thanks for any advise.
MarkL
You may get several different answers, but when I construct raised panel cabinet doors I generally stain the stiles, rails, and panels prior to assembly. Same with the poly, but I wipe on thin coats of a poly / thinner mix. Those out there who brush or spray may have a different process. Either way, use spacers in the grooves the panels sit in. I use little rubber "spaceballs" (brand name). Two or three along each edge is plenty.
Thanks for the advise.
Finish the panels and the pieces of the door separately. Then assemble the whole thing, being careful with your clamps.
Remember that the finish will make the panel edges slightly thicker, so a loose fit now may very well be too tight once it is finished...
d-
Thanks for the advise on the pannel edges. I plan on sanding the backs of them a little more to ensure they fit after finishing.
Mark,
Your comment about sanding the backs of the panels after finishing them suggests that you might leave the backs unfinished.
Both sides of a floating panel should be finished the same way to minimize warping caused by unequal moisture absorption from the air. In theory the frame around the panel will control the warping but you shouldn't push your luck, the frame can take on a twist from a badly warped panel. Also if the panel warps before you get it in the frame, assembling the door may be difficult or impossible.
John W.
Thanks. You're correct. I miss spoke. I plan to sand the backs before finishing.
You could do it either way,but remember polyurethane will not prevent wood movement. I'd construct the entire piece before staining/finishing because otherwise you'll have to tape off or cover all the joints because stain can affect glue absorption.
Mark,
The reason for staining the panels first is so you don't have unstained borders showing should the wood shrink. To my mind, this is a lot more obvious than having an extra coat of finish on the panel.
That's why I stain and finish the panel prior to construction. I don't stain the stiles and rails until after assembly, so I can plane them flush first. The stain tends to wipe off the pre-finished panels without darkening it.
Dan
Thanks for the advise. I think this is the way I will go.
