I am planning on setting up an area apart from my shop where I can do my spray finishing. I have one small space (approximately 6 X 10 feet) located next to the furnace room where we have both a gas furnace and hot water heater. This space does have a window that could be used to vent directly outside. My thought was to use an explosion-proof fan. I want to be able to spray a variety of finishes and am concerned about creating a fire hazard if I use this space next to the furnace room as a spray booth. Any thoughts??? Sciman
I do not spray my finishes so I cannot speak to safety issues concerning them. I do know that lacquer is heavier than air and down low is where your pilot light is on a water heater. I wouldn't put a spray booth anywhere near an open flame source such as you're considering. But that's just me.
I would contact your fire marshal and gas company on safety precautions and regulations.
I do spray finishes and absolutely second what Gary said. Lacquer fumes are heavy and will travel to a source of ignition. In your case that ignition source is very close making the space you spoke of impractical and dangerous.
Peter Gedrys
I don't know if my reply came to you.
I do spray finishes and I absolutely second what Gary said. Lacquer fumes are heavy and will travel to the source of ignition. Since that source is so close it makes that space impractical and dangerous
Peter Gedrys
