I have been scrolling for about a year now. I currently use Baltic Birch as I don’t have the means to resaw, plane, etc. regular wood. The problem I have is keeping the stain on the fretwork during finish sanding. After staining I add Sanding/Stain Sealer. I currently use water based products sold at the Woodcraft stores. When I try to sand [with 320 grit paper] invariably some of the stain is removed, typically at the ends of the frets.
Would more coats of the Sealer solve this problem or is there a different methodology needed? I am a real novice at finishing so don’t spare the details!
Thanks is advance.
Dick
Edited 3/6/2003 10:32:35 AM ET by senior85222
Edited 3/6/2003 10:35:01 AM ET by senior85222
Hi Dick,
A few things I would do differently:
first, I'd practice a new finishing procedure on sample blocks,(3"*3") and if it didn't work out, I'd try something else.
With the procedure you described, I would skip the sealer entirely. Birch really doesn't need it, try it on a sample block. I would finish sanding to the finest grit I was planning to use before coloring the wood. If the coloring agent is water based, try wetting the surface of the piece with plain water, let it dry and then sand off any raised grain with the final sanding grit used before. That should take care of any problem from the staining solution fluffing up the surface. Then hit it with your stain. Then finish with varnish, shellac, whatever you prefer.
You might also want to experiment with dyes. Behlen's Solar Lux is a good NGR dye and I believe Woodcraft sels it, but I'm not really sure of that. I know they sell aniline dyes in powder form (Very powerful stuff- a badly timed sneeze can really ruin your day, as I found out the hard way with some malachite green) I prefer dyes over stains and think they are worth the effort.
Anyway, I would not sand after staining, or at most, give it a light scuff sanding(2 or 3 light strokes) with very fine grit paper.
Hope that helps,
Christopher
Thanks for your ideas. They make good sense. I will give them a try when I get home which wont be for a few weeks. I will let you know then how things work out.
I have never tried dyes, but it is never to late to start!
Thanks again,
Dick
