I have resawed some spalted maple into 1/4″ x 14″x14″. These will be panels inserted into the doors of a walnut pie safe. I want to put a finish on the maple. So far I have applied a coat of Minwax Poly Semi-Gloss on a scrap. It was turned dark. Also tried a 50% solution of tung-oil which also turned the maple dark. I want to keep the light natural look of the wood. Any ideas? Have checked several blogs and everyone has a different product and idea. Don’t want to buy 5 different products.
You could try a couple of things:
- a "clear" shellac. Zinsser's Seal Coat, or mix your own from ultra blonde flakes. This will impart a bit of a yellow color, so may not be your ideal choice.
- a waterborne poly, rather than an oil base. Oil-based polys do add yellowing, waterbornes are clear.
Clear waterborne acrylic will add the least color to maple. It will be virtually water clear. Minwax Polycrylic or a comparable General Finish polyacrilic will work fine. Test them on your scrap.
Ultrablond shellac will add no color to the maple and will not itself yellow with age.
CAB Acrylic lacquer goes down "water white" (colorless), and while it handles exactly like nitrocellulose (same solvents) will not yellow at all with age as nitro does. Use ultrablond shellac as a sealer or use CAB Acrylic high solids sealer first.
Most any water-borne finish will add no color and will not itself yellow or darken.
Unfortunately, maple itself yellows and darkens slightly with age under any finish. Some samples less, less some more. Some rapidly, some slowly. I've seen a very slight whitewash treatment, prior to finishing, to be very effective at preventing any discernable yellowing over many years.
Rich
