Hello to all, this is my first time on this forum and I sure hope there is someone out there who knows the answer to my problem.
I do a lot of restoration work. Whenever I need to replace rotten wood, I use Spanish Cedar. I love the wood and have acummulated a healthy pile of leftovers. I want to panel “my bathroom’ (1/2 bath, no shower) with it. The smell of the stuff is so pleasing to me, and it simply looks beautiful. So here is the big problem… how do I apply a finish that will not block the aromma in. linseed oil and turpentine has been suggested to me. Anyone have any other suggestions? thank you for any help
For your purpose, no finish is the best finish. If the walls get dirty, sand them periodically.
I have thought of that, whoever I would love to bring out the richness of the wood a little. when sanded up, the surface is so soft and seems to need some kind of thin sealer to tighten up the surface. I know it sounds counter productive to seal the surface while still wanting the natural oils in the wood to be allowed to come out. I feel there is some sort neutral oil that will suit both needs. Commercal walk-in humidors seem to have some sort of finish and the smell seams to come forward... who knows, might just be all the boxes stored in the room.
You could try mineral oil, which will not dry to a hard protective film, and should add depth.
Excellent suggestion!!! I'll try that on a sample today. Thank you so much...
I don't think I would use mineral oil. It never dries, It will attract dirt and dust and probably get grimy looking. I would probably go with a wipe on poly. And make a poperee(SP) bowl and put cedar shavings in it.Work Safe, Count to 10 when your done for the day !!
Bruce S.
I would not finish it if you want the aroma. The wood inside a cedar chest and that used to line closets is not sealed.
This is a case of either/or. Either you have the odor OR you seal it to bring out the color of the wood. If you want to seal it, I would use shellac.
" There'll be no living with her now" - Captain Jack Sparrow
Seems to me you're going to have to compromise. Leaving the wood bare in a bathroom will likely last only a few weeks before it looks ratty. Sealing it with shellac or poly will eliminate the smell. A coat or two of linseed oil will breathe a bit, but it has its own smell. It would be worth testing a piece with a coat of linseed oil and seeing (and smelling) what you get after 2 weeks. No matter what you do, the smell will fade over time if left in the open so your best bet may be to chop your scraps into potpourri.
Pete
joining this forum has been a good move.... lots of great input from you folks. I plan to try out a bunch of different samples today.
