I am looking for a finishing system for soft wood like Australian red cedar. I don’t like plastic finishes and like oil finishes. Problem with red cedar is that absorbs a lot of oil and you get a dark uneven finish. It is a very attractive timber and it is a shame to get an uneven finish. Is there something you can do to make oil finishes work better or is there another better suited finishing system with similar feel to oil?
Personally, I think most softwoods look better unfinished. How is this wood going to be used? Indoors or outdoors? You'll probably have the best luck by either using a lightweight, penetrating oil finish, or by sealing the wood first with shellac and then (optionally) applying another finish on top of that.
I used Bio-Wash Natural Deck Oil on some Alaskan yellow-cedar, and it looks pretty good. There's a very slight gloss, but no noticeable surface build.
Edited 9/18/2007 10:46 pm ET by saschafer
Thanks for your reply. It will be indoors. It has very nice colour and figure and needs a nice finish
I have a beautiful piece of Red Cedar in my workshop that is destined to become 4 drawer fronts.
I plan to use a split coat of shellac to seal, then finish with Danish Oil.
That cedar looks a lot like some of the bits I have. What do you mean by a 'split coat'of shellac?
A split coat is just a weak solution of shellac. I generally try one about 1/3 full strength.
Derek's "split coat" is also called a wash coat in these here parts.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
