i am finishing construction of a large walnut blanket chest for my daughter’s wedding (which happened two weeks ago; i am a bit behind). I am considering using a brushable lacquer finish. what grit is it best to sand the walnut to? Should i use shellac as a sealer? where can i get some guidance over best practices; it truly is an heirloom piece and i want the finish to be both durable and easy to repair. any thoughts?
I've never been happy with brushing lacquer
Rich,
The following link has some information on finishing walnut.
http://rlmillard.typepad.com/my_weblog/2008/09/index.html
(you may need to copy and paste this link)
I'm not a real fan of brushing lacquer. It is quite thick, making it difficult to use on detailed pieces. Shellac would be my choice. It is easy to apply and provides more than enough protection for a blanket chest. You may want to use something more durable for the top, such as brushing lacquer or a varnish.
Rob Millard
Sanding to 180 grit would be sufficient under a film finish. You can use shellac under lacquer, but the only reason for doing so is if you are after it's color. Lacquer will work fine as it's own sealer.
Have you used brushable lacquer before? It does have it's own foibles in how it is applied. Further, it is only a a tad more protective than shellac, and is less long lived than shellac.
You should consider whether you want to fill the pores in the walnut?
Blanket Chest
Rich,
Sanding the wood to 180 is fine -
Are you staining - a wiping stain can help fill the grain - followed by shellac -
For finish go with a spray can lacquer - trying to brush a blaket chest is too much trouble -
SA
