I am just finishing up an entertainment center for my already out of date television. I built it with wood salvaged from the walls of a barn here in New England (titletown USA). It was installed as 2 3/4″ t&g bead board. At first I was sure that it was Doug fir, but when I got back to my shop, it looked different from the piece of doug fir flooring I had laying around. The grain is more pronounced and darker,and it seems harder than the doug fir. I had enough of it that I was able to pick through it and get all the straight grain for the cabinet doors and I used the flamier, flat sawn stuff for the sides. Any way, does anybody have any guesses as to the species? Yellow pine? and does anybody have a favorite finish for this wood.?
strando,
Fir or Douglas Fir is a very tough wood to finish without getting the "blotch" problem.
However, one technique that I learned from Jeff Jewitt was to mix 7 parts Odorless Mineral Spirits with 1 part of Boiled Linseed Oil. Wipe down your project with this mixture. Then follow up this "homemade conditioner" with some Watco or a stain of your choice. Once your stain/oil dries, then top coat and you are finished.
Cheers!
Dark Magneto
Hello,
Saw your post and have a few questions regarding Jeff Jewitt's technique.
Does that technique replace Minwax's Wood Conditioner? Does it work better? Can you use dye instead of stain?
Steve Monson
Thanks for the posts. I have the same questions about the spirits & linseed oil treatments.
Steve,
Yes, basically the Mineral Spirits and BLO is wood conditioner.
I'm not too sure about how a dye would work in place of the stain. My thinking is that the MS and BLO are "oil" products and the dye is usually a water or alcohol based product. I have only used a MinWax stain in conjunction with the Doug. Fir and it turned out fantastic! I used the "Puritan Pine" color from MinWax.
So use the MS and BLO mixture in place of your wood conditioner.
Cheers!Dark Magneto
Thank you!
I have never used dyes before, but I want to experiment with them, so I will also experiment with this process as well.
Thanks again
Steve
Steve,
Jeff Jewitt's new book is a really big help when it comes to finishing. He goes into great detail (but not over-board) on using dyes and stains.
I think the book is around $40, but it is well worth it.
Best of luck!Dark Magneto
If the barn was built out of locally cut and milled wood, it couldn't have been Douglas fir or yellow pine, neither grows in New England. Without seeing the wood, this is purely a guess, but you may be working with eastern hemlock.
John W.
