I have been in the market for a new drill press for some time. Until recently, I have been using the old Shop smith for the drill press. I wanted a full height version .vs. a bench top. I had a bench top a long time ago, but was never really satisfied. I had been looking at the Delta 16 ½ drill press until I went to the St. Louis Wood working show a couple of weeks ago. At the show was a display of Fisch tools. The salesman discussed a drill press that was a new addition to their line up. I immediately liked what I saw. <!—-><!—-> <!—->
The features I liked: <!—-><!—->
- The table:<!—-><!—->
- Large size 13” x 14”<!—-> <!—->
- Square with tapped holes in each corner<!—-> <!—->
- Very flat. Using a machinist’s edge only .0015 off at one corner. I work with wood, so I don’t see how that will make a big difference. <!—-><!—->
- Quick tilt mechanism. It has positive stops at 0, 45 (both sides), and 90. Its very smooth action. I checked the table to the quill with a set of machinist’s squares and a 45. Both were dead on. I have not seen a quick positive stop before. <!—-> <!—->
- Lift Mechanism:<!—-><!—->
- Very smooth on the raising and lowering<!—-> <!—->
- Metal spring loaded locking mechanism that locks the table to the column <!—-><!—->
- Easily rotates the table out of the way if you need to<!—-> <!—->
- Quill: <!—-><!—->
- The smoothest of the drill presses I have tried. I really liked that if I let go of the handles it would not break my knuckles. <!—-> <!—->
- The quill lock has a groove that gives it a flat place for the quill lock to byte. Once I had it locked down, it held great <!—-> <!—->
- The handles on the Quill are 10” long. It made it very easy to get good leverage. <!—-><!—->
- The chuck:<!—-><!—->
- It has a taper that slides into the quill shaft. <!—-> <!—->
- The chuck is 5/8 and nice quality. Very smooth action. <!—-> <!—->
- The run out on the chuck was .002. I’m tried several bits to test this, and a few router bits. I assumed they would be pretty strait. I don’t know if .002 is way off or not. I don’t think it will matter in wood anyway. <!—-><!—->
- The best of the rest:<!—-><!—->
- The motor is 3/4hp at 1750 rpm. I tried a 2 1/8” fortneser bit at 215 and cherry, and no burns, and no bogging. I also did a lot of spiral brad point bits, and no issues at all. No grunts or groans. <!—-> <!—->
- The dept stop is solid and I had no variations over a bunch of holes. <!—-><!—->
- The fit and finish was excellent. <!—-> <!—->
The only issues I found<!—-><!—->
- Three plastic parts, the quill stop handle (same on the Delta), the cover of the electrical switch, and the top of the drill press. Not a real issue. <!—-> <!—->
- Its not variable speed. Minor. With the cost of a variable speed, I can change a few belts. I probable will not use more than a few anyway.<!—-> <!—->
- The brand. It’s not a problem, but I don’t know anything about them. I came back from the show on Saturday and tried to do some research on them, but could not find much on the internet. I took a chance with Grizzly and it has worked out, so I will take a chance here
Summary: <!—-><!—->
So far I am very pleased. It has all the features that I wanted and a price point that could not be beat. It was the show demo, and he sold it for $329. I bought it, and came back in about 30 minutes and he had it ready to take to the van. When I got it home, I discovered that he had forgot to put the chuck key in the box. I sent an E-mail to him that evening and he apologized and sent me the chuck key right away. He also included a 7 piece brad point bit set as well. I did not realize at the time that it was Anthony Hinch the President and CEO of Fisch that sold me the drill press. The drill press comes with a two year warrantee. If you are in the market for a drill press give them a look. I took a chance and let’s see how it works out. I have included some pictures to give you an idea of the machine. In the future if someone is interested in the brand, I hope this helps. Take care. <!—-> <!—->
I've had this drill press for 2 years. The 5/8" is less than desirable. I've cursed the machine many times because of the cheap chuck. Once I get a new chuck I believe I will be fully satisified with the machine.
Curious what the problem with the chuck is? Mine is very smooth and the 5/8 will handle what I can throw at it. What size do you want to change to?
The size of the chuck is fine. My chuck has gritt feel to it and it binds so it is very difficult to get the chuck to engage with the bit without applying accessive force.
I see now. Contact them and get a new one. It has a two year warantee.
Replacement parts? Where to find?
Hello, the park district that I work for had purchased the 17.5" Fisch drill press before I came onboard, so I cannot find any supplier/seller information. Recently the colunm lock handle snapped off when tightening it down, and I need to find a repalcement for the handle as soon as possible. (handle as shown in your photo #5). Do you have any idea where we can get replacement parts for Fisch Precision Tools nowadays? I cannot find a source for maintaining this great tool.
Please let me know if you have any information that can help me out.
Thank you for your review, I agree with it all. It has been a hard-working, reliable tool, up until now.
Sincerely, R. Kitamata
Exhibit Design
East Bay Regional Park District
The Fisch 17-1/2 drill press is certainly a quality machine for the money. Some nice features such as the tilt bed and easy-to-use levers are handy. Factory people are very friendly if you need assistance--which you probably won't. Having an attached light would be a nice improvement. The machine is made in China but the competitors are too. All-in-all this is a good machine that I'm happy to have in my shop.
