I have some raised panels where the joints are not as tight as they should be. Is there a technique or fix for minimizing it’s appearance?
If the space shows on the front - maybe you can add a small molding -
Would shimming from the back push the panel forward and hide the space ?
SA
Are you speaking of the joints between rails and stiles, or between panel and the frame?
just make new ones. that way you may learn how to make them fit
ron
