I’ve been giving a lot of thought to building a flagpole. I would place the pole on a concrete base (already there) securing it with a piece of steel plate and bolts to the concrete (bolts already embedded in the concrete.)
Some would say just get a reasonably straight pine tree trunk, true it up and erect it. For one thing I don’t think this design is very strong- for another the aesthetic value would leave me with something to desire.
I recall sometime back that a guy built his own five sided tapered pole out of yellow pine 35′ tall. This seems to me to be the way I want to go but I can’t find any source stuff on the design nor the construction.
Anybody got any thoughts?
Windy Wood
From the Helderberg Mountains
Build a mast and anchor it to a weldement base, which would be anchored to the cement foundation.
For mast-building help and resource for plans, see http://www.woodenboat.com/. You might also read Howard Chappelle's chapter on mast building in his book, Boatbuilding (W.W. Norton & Co.; it may be out of print); or Steward's, Boatbuilding Manual (International Marine Publishing Co.). Both those books have a pretty good description of mast (spar) building.
Namaste,
Gary
http://gwwoodworking.com/
THIS OLD HOUSE featured a wooden flag pole on one of their project houses a few years back. The supplier for that pole can be found at: http://www.woodenflagpoles.com/
You might get some ideas from them. Norm Abrams has constructed a similar pole for this seasons NEW YANKEE WORKSHOP. The episode has not aired yet but the plans and video are available at: http://www.newyankee.com/getproduct3.cgi?0309
Thanks, LR-
I will check it out.
Windy Wood
Just saw the NYW show with the flagpole,very much like mast making. A good method and lots of good tips on jig/template alignment and long-assembly fabrication.If it is to be.... 'twil be done by me.
Thanks!
I have already ordered and received the plans and videotape from the NYW. The flagpole is quite a bit shorter than the one I plan to build but the methodology should translate very well. I'll report back when I do the project.
Windy(:-)
Windy Wood
