gary,
is there a way to flatten a warped sheet of plywood,if so how?
thank you,tazzer
Tazzer,
Bad news. The only method I have involves using about 50 $1 bills or 100 $1 bills if it's an exotic veneer. Bring the warped plywood back to your lumber yard. Then tell the guys to get you a new piece of flat plywood. This will usually work. It helps to check the new sheet before leaving.
Sorry I don't have a reliable method for getting a warped sheet flat. Gary
