How do you flatten a 220 grit Norton Waterstone? Do you have to buy one of those zig-zag cut pink stone flatteners or can you use sandpaper on glass?
– Peter
– Peter
To flatten all my waterstones, I use a course grit DMT diamond plate under running water.
Steve
If you want inexpensive try adhering wet/dry sandpaper to a piece of plate glass, granite tile, or marble tile. I've heard of people using sandpaper on a cinder block which is suprisingly flat. Keep water on the surface to wash away cut stone.
There are more old drunkards than old doctors. Ben Franklin
