Flattening water stones. I’ve used water stones for years but never bought an expensive ‘flattener’. I one of my DMT diamond stones but I’ve never heard anyone say whether that is a good idea or not. It seems to work but I wonder if I’m missing something?
I have seen a lot of people recomend flattening water stones with a dimond stone. Being somewhat tight with a dollar I worry about wareing out the diamond stone. I have had good succsess with a piece of drywall sanding screen on float glass.
Good luck
Troy
Someone posted along the lines you mention. The theory is, your waterstone cannot, obviously, wear down the diamonds in a diamond plate. But the abrasives in your stone can abrade the substrate holding the diamonds. Over time, flattening your stones will wear out the diamond plate.My goal is for my work to outlast me. Expect my joinery to get simpler as time goes by.
I'm with Toolfreak. The Norton flattening stone works great, and is a very good value at about $25.Ken
And the eternal question is.......How do you flatten the flattening stone?
Well, I haven't gotten that far yet, but after flattening about 6 times, I don't see any change in the flattening stone.Maybe I'm naive, but I bought the Norton flattening stone to flatten my Norton 4K/8K combi stone, assuming that the fine folks at Norton would provide products that will actually do what they claim, without undue premature wear.So far, I'm quite happy with both items.Your question is a good one, thanks for asking it.Ken
I actually have the Norton stones too, including the new green flattening stone. It does a good job. Eventually I will true it up on some sandpaper on a granite plate.
People, do not use a hundred dollar diamond stone to flatten a thirty dollar water stone. There are plenty of alternatives.
I use my 200 grit waterstone to flatten my 1000 and 8000 stones. Rub them together wet and it takes 30 seconds after honing.
Eric
If it works, then there isn't any issue with it. You can also use silicon carbide wet/dry sandpaper on float glass for flattening or you could use other waterstones for flattening the finer grit.
I bought the Norton flattening stone from Hartville tool recently for 22.99 and I like it better than using sandpaper and it does not take as long to do it, I would not go back to sandpaper , too much of a hassle for me.
I have never tried this, so I can't vouch for it, but have read that a cinder block does a good job of flattening water stones. If true, it must be about the cheapest solution out there...
I use a cinder block all the time to flatten my 200 grit stone. And then I use it to flatten the next finer stone, etc.. The block wears hollow in the middle but it keeps on working because the stone is also hollow. When the pencel marks on the stones are gone, quit rubbing. I use the wall capper blocks they are the easiest to store.
Edited 1/19/2006 7:16 pm ET by Hockey puck
Since I first posted I finally found a 1/2 inch piece of glass to use with wet/dry paper. I used a fine grit dry wall sanding screen to use on my water stones and it works great. Now I'm working on all my planes and chisels to re-flatten them.
